PROBLEM
Unable to install the Portal for ArcGIS Application Display Patch
First Published: August 8, 2024
Last Published: August 8, 2024
Attempts to install the Portal for ArcGIS Application Display Patch fail because the process is interrupted on the installation wizard. The installation wizard also does not allow the selection of an install directory.
Cause
The Portal for ArcGIS Validation and Repair tool is not installed on the machine.
Solution or Workaround
Download and install the Portal for ArcGIS Validation and Repair tool. Refer to Esri Technical Support Patches and Updates: Download from this page for instructions.
For additional information regarding the Portal for ArcGIS Application Display Patch, refer to Esri Technical Support Patches and Updates: Portal for ArcGIS Application Display Patch.
Article ID: 000033240
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
