PROBLEM
Attempts to install, update, or apply a patch to ArcGIS Pro 3.5 or later fails, and the Windows Installer returns the following error message:
Error: The feature you are trying to use is on a network resource that is unavailable. Click OK to try again, or enter an alternate path to a folder containing the installation package 'ArcGISPro.msi' in the box below
Warning: The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding.
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
Note: If prompted, click Yes in the User Account Control window to allow the app to make changes to the device.
to expand the registry key folders in the folder tree.HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products
Note: To identify the corrupted program, click each subkey folder, then double-click ProductName on the right. Check the Value Data in the Edit String panel. Signs of a corrupted program include the Value Data box being empty, missing data, or containing garbled and unreadable characters. Delete the subkey folder if the ProductName matches the product being installed (ArcGIS Pro).
Perform a clean uninstall of ArcGIS Pro to remove corrupted installation or registry entries, then reinstall using new installation files. Refer to How To: Perform a clean uninstall and reinstall of ArcGIS Pro for instructions.
Article ID: 000038294
Get help from ArcGIS experts
Start chatting now
