PROBLEM
Unable to input decimal separators in the ArcGIS Survey123 surveys
First Published: December 15, 2022
Last Published: December 15, 2022
Unable to input decimal separators such as decimal points or decimal commas in surveys configured in ArcGIS Survey123 Connect. In some cases, inputting decimal commas does not work when responding to surveys on certain Samsung devices.
Cause
  • The Windows regional setting is set to a region that uses a different decimal separator.
  • The Windows decimal symbol setting is set to a different decimal separator.
  • The question type is not set to decimal in ArcGIS Survey123 Connect.
  • Decimal commas are not supported on certain Samsung devices. For more information, refer to ArcGIS Survey123: Form behavior.
Solution or Workaround
'Decimal' is selected in the type column.
Alternatively, select the esriFieldTypeDouble field type in the survey worksheet of the XLSForm to allow decimal inputs and overwrite the default field type.
Article ID: 000028898
Software:
  • ArcGIS Survey123 Field App iOS
  • ArcGIS Survey123 Field App Android
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
