PROBLEM
When a web map is embedded in a website, attempting to geosearch an address using the Location Search bar fails if the address is located outside the current extent of the web map.
By design, the default HTML code generated when embedding a web map in a website includes a 'searchextent' parameter that is set to 'true', limiting geosearches to the current extent of the web map. Therefore, the expected result of the geosearch is not returned when searching for an address not located within the extent of the web map.
The Current Extent check box does not appear until the Location Search check box is selected.
![[O-Image]](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000012669/00N39000003LL2C-0EM39000000wdig.png)
Alternatively, the web map can also be published as a web application. For more information, refer to HowTo: Embed an ArcGIS Online web application in a website.
Article ID: 000012669
Get help from ArcGIS experts
Start chatting now
