PROBLEM
Unable to filter the target elements in ArcGIS Dashboards according to the map extent
First Published: October 18, 2018
Last Published: September 20, 2024
The target elements in ArcGIS Dashboards are not filtered according to the map extent.
The image below is a dashboard showing crime occurrences in Redding, California, during the fourth quartile of 2017.
This is the dashboard before being zoomed in.
When zoomed in, the target elements are not filtered and updated according to the changes in the map extent.
The map in the dashboard zooms in.
Cause
The issue occurs because the setting for the map behavior is not configured properly. Setting the Filter action in the 'When map extent changes' section for the source element (the map), and specifying the desired target elements (Pie chart, Serial chart) filters the target elements automatically when the map extent changes.
Solution or Workaround
To filter the target elements in ArcGIS Dashboards according to the map extent, use the following workflow:
  1. In ArcGIS Dashboards, hover over the top-left corner of the map element. Click the Configure button to open the Map window.
The Configure button displayed on the top-left corner of the map element.
  1. In the Map window, select the Map actions tab. Expand Filter.
  2. Toggle on the desired target elements from the drop-down list. More than one target element can be selected. Click Done.
The Map actions configuration.
The target elements are filtered automatically when the map extent changes.
The target elements are updated when the map zooms in.
Article ID: 000018933
Software:
  • ArcGIS Online
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
