PROBLEM
Unable to export a tile package from the World Imagery services
In some cases, attempts to export or extract a tile package from the World Imagery (for Export) service fail.
Cause
The World Imagery (for Export) map service is designed to support exporting small volumes of basemap tiles for offline use, according to the access and use constraints. However, the size of the basemap exported with the web map can reach a limit that can cause the download to fail. Basemap services are configured by default to prevent the export of more than 100,000 tiles. Refer to Problem: Unable to download a map for offline use in Collector for ArcGIS for more information.
Sometimes, the failure may be due to service disruptions when servers are experiencing downtime. This issue is only temporary. When the issue is resolved, and the service resumes operating normally, access the services once again. The status information for ArcGIS Online services can be viewed at ArcGIS Online Health Dashboard.
Solution or Workaround
To export tiles from the World Imagery, use the instance of the World Imagery hosted on the tiledbasemaps.arcgis.com server referenced by this map service item, which has the Export Tiles operation enabled. To generate a tile package from the World Imagery service, follow the steps below.
This method requires an organizational account, but does not consume credits.
  1. Browse to the World_Imagery (MapServer) page.
Enter a token.
  1. Enter a token to grant access to the service. Use the following URL to generate a token:
https://<organization short name>.arcgis.com/sharing/generateToken?f=json&username=<username>&password=<password>&referer=https://www.arcgis.com
It is best to generate the token using administrator credentials. Refer to ArcGIS REST APIs: Generate Token.
  1. After logging in, the REST page for the service is displayed. Scroll down to the bottom of the page, and click ExportTiles.
  2. In the Export Tiles page, enter the following parameters to generate a tile package.
    1. Tile Package: Edit the value from false to true.
    2. Export Extent: Enter the extent in Web Mercator coordinates to define the area to export.
    3. Export By: Select Level ID, and enter level ID(s) to export in the box under Export By.
    4. In the Polygon section, remove the default syntax.
    5. Area Of Interest (Polygon): Leave the default syntax.
    6. Format: Select HTML.
  3. Click Export Tiles.
  4. In the Jobs Status page, check the status of the job submitted, and refresh until it is done.
  5. Under Results, click out_service_url. Copy and paste the URL into a new tab.
  6. Click layer.tpk to download the tile package.
Article ID: 000014855
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
