PROBLEM
Unable to export a side-by-side comparison infographic PDF report for all buffers in ArcGIS Business Analyst Web App
Last Published: February 1, 2023
In ArcGIS Business Analyst Web App, when attempting to export an infographic PDF report for all buffers of a site, only one of the buffers' infographics is displayed in the report. As shown in the image below, exporting the infographic PDF report results in only one of the buffers' infographics with a radius of '0 - 1 miles' displayed in the panels.
The infographics panels in the exported infographic PDF report
Cause
This is by design when a comparison table is added to a panel of an infographic template. Adding a comparison table to a panel causes the panel to display a drop-down menu of the buffers in the app, therefore allowing only one set of data from a buffer to be displayed and exported to an infographic PDF report at a time.
The infographics panel in the exported 'In app' export mode
Solution or Workaround
Follow the workaround below to export a side-by-side comparison infographic PDF report for all buffers in ArcGIS Business Analyst Web App by deleting the comparison table and adding a table with variables in the infographic template.
  1. Log in to ArcGIS Business Analyst Web App.
  2. On the Reports tab, click Build Reports > Build Infographics.
The Build Reports and the Build Infographics options
  1. Hover over the existing template and click Open.
The Open button
  1. In the infographic builder, hover over the comparison table element and click Remove panel.
The Remove panel icon
  1. Add a table with variables to the panel. Refer to ArcGIS Business Analyst: Add a table with variables for instructions.
  2. Click Save.
The Cancel and Save buttons in the infographic builder
  1. In the Save Infographic Template window, rename the template title if necessary and click Save. In this example, the template is saved as 'Total Expenditures (Tables with Variables)'.
The Save Infographic Template window
  1. On the Reports tab, click Run Reports > Run Infographics.
The Run Infographics and Run Classic Reports options
  1. Click Add sites. In the Add Sites window, select a site and click Apply. In this example, 'CITY HALL ANNEX' is selected.
The City Hall Annex site
  1. Under Select infographics to run, expand My infographics, and select the custom infographics template. In this example, 'Total Expenditures (Table with Variables)' is selected.
My infographics templates list
  1. In the Selected infographics pane, click Run now.
The Run now option in the selected site pane
  1. Click the site details drop-down and toggle Side by side comparison on for a side-by-side comparison in the app.
The Side by side comparison toggle button
  1. Click Export infographic Export infographic on the top ribbon to export the infographic.
  2. In the Export Infographic window, ensure Export as is set to PDF and click Create PDF to download the infographic PDF report.
The Export Infographic window
The image below demonstrates the exported PDF file with a side-by-side comparison infographic for all the buffers ('0 - 1 miles', '1 - 3 miles', and '3 - 5 miles').
The exported side by side comparison infographic PDF report for all buffers of a site
Article ID: 000029129
Software:
  • ArcGIS Business Analyst Web App
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
