PROBLEM
Unable to edit the text alignment in callouts in ArcGIS Pro
First Published: May 28, 2021
Last Published: May 28, 2021
In ArcGIS Pro, the horizontal alignment controls how multiline text is aligned. In some instances, the horizontal alignment option is unavailable and it is not possible to modify the text alignments in the callouts.
In the Label Class pane, on the Symbol tab, under the Position section, the horizontal alignment option is disabled and grayed out.
The image below shows the callouts on a map with left-aligned text.
Two callouts with transparent white background and blue borders.
Cause
The unavailable horizontal alignment option is for text symbols. The callouts are stacked labels, and the horizontal alignment can be modified under the Stack section in the labeling properties settings.
Solution or Workaround
Use the workflow below to modify the alignment of the callouts.
  1. In ArcGIS Pro, in the Contents pane, right-click the layer containing the callouts, and click Labeling Properties....
The Label Class pane opened in the Contents pane to modify labeling properties.
  1. In the Label Class pane, click Position, and click Fitting StrategyThe knight chess piece icon representing Fitting Strategy..
The Label Class pane to access the Stack labeling section.
  1. Expand Stack.
  2. For Horizontal alignment, click the drop-down arrow, and select the preferred option for the text alignment in the callouts. Refer to ArcGIS Pro: Stacked label alignment for more information. In this example, Constrain center is selected.
The Label Class pane to expand Stack.
The image below shows the callouts with center-aligned texts.
Two callouts with transparent white background and blue borders and the text in the callouts are aligned to the center.
Article ID: 000025416
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
