PROBLEM
In Portal for ArcGIS, when attempting to edit a related table using the Edit widget in ArcGIS Web AppBuilder, the related table pop-up continues loading, but does not display the related table’s information.
This is a known issue resulting from the installation of Portal for ArcGIS Security 2020 Update 1 Patch or Portal for ArcGIS 10.7.1 High Availability Licensing Patch. Refer to BUG-000132131 and BUG-000129924 for more information.
Use one of the following workarounds to resolve:
Install Portal for ArcGIS High Availability and Disaster Recovery Quality Patch as a replacement
Install Portal for ArcGIS High Availability and Disaster Recovery Quality Patch as a replacement for Portal for ArcGIS Security 2020 Update 1 Patch or Portal for ArcGIS 10.7.1 High Availability Licensing Patch.Note: Uninstalling Portal for ArcGIS Security 2020 Update 1 Patch or Portal for ArcGIS 10.7.1 High Availability Licensing Patch is not necessary as installing Portal for ArcGIS High Availability and Disaster Recovery Quality Patch fully replaces the older patches.
Upgrade Portal for ArcGIS to version 10.8.0 or later
Upgrade Portal for ArcGIS to version 10.8.0 or later. Refer to Portal for ArcGIS: Upgrade your ArcGIS Enterprise portal for more information.
Article ID: 000024434
Get help from ArcGIS experts
Start chatting now
