PROBLEM
Unable to edit hosted feature layers in ArcGIS Enterprise
Last Published: July 28, 2025
In ArcGIS Enterprise, features in hosted feature layers cannot be created or edited. This issue affects editing workflows across multiple platforms, including Map Viewer, ArcGIS Field Maps, and other apps. When it occurs, the ArcGIS Server Manager log file records an error message similar to the following example.
Error:
0 : ERROR: cannot execute <query> in a read-only transaction
Where: SQL statement "SELECT base_id, num_ids FROM <target_table> WHERE id_type = 2 ORDER BY num_ids DESC FOR UPDATE"
PL/pgSQL function <id_generation_function>(integer, integer) line 45 at OPEN
SQL statement "SELECT sql_code, o_base_id, o_num_obtained_ids FROM <id_generation_function>(2, 1)"
PL/pgSQL function <rowid_management_function>(character varying, character varying) line 34 at EXECUTE
Error message from server log file
Cause
The issue occurs when ArcGIS Data Store (relational) silently switches to read-only mode, preventing any operation that writes to the hosted layer. This is because the ArcGIS Data Store has a built-in safeguard mechanism that automatically changes the data store mode to read-only when the disk space on the machine hosting the relational data store drops below a critical threshold.
Solution or Workaround
  1. Increase the disk space of the ArcGIS Data Store machine. Refer to ArcGIS Enterprise: Disk space requirements for more information.
  2. Change the relational data store from read-only to read-write mode. Refer to the solution section of the following article, Error: Failed to submit ArcGIS Survey123 response. Database error has occurred for instructions.
Article ID: 000037089
Software:
  • ArcGIS Data Store
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
