PROBLEM
Unable to edit features in ArcGIS Field Maps
First Published: November 11, 2022
Last Published: November 21, 2024
In ArcGIS Field Maps, new features can be added to a map for data collection. However, in some cases, the Edit option is not available, as shown in the images below.
ArcGIS Field Maps (Android)
Options for a point feature in ArcGIS Field Maps on an Android device.
ArcGIS Field Maps (iOS)
Options for a point feature in ArcGIS Field Maps on an iOS device.
Cause
The Update option of the hosted feature layer is not enabled in ArcGIS Online.
Solution or Workaround
  1. Ensure pop-ups are enabled on the web map using ArcGIS Online Map Viewer. Refer to ArcGIS Online: Configure pop-ups (Map Viewer) for more information.
  2. Log in to ArcGIS Online with the same credentials used in ArcGIS Field Maps.
  3. Click Content > My Content.
  4. Browse to and click the hosted feature layer used in the ArcGIS Field Maps web map.
  5. On the item details page, click the Settings tab.
  6. Scroll down to the Feature Layer (hosted) section and check the Update check box under the What kind of editing is allowed? setting.
The 'What kind of editing is allowed' setting in ArcGIS Online.
  1. Click Save.
The images below show the Edit option is available in ArcGIS Field Maps.
The option to edit the point feature is available on the Android device.
The option to edit the point feature is available on the iOS device.
Article ID: 000028650
Software:
  • ArcGIS Online
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
