PROBLEM
In ArcGIS Pro, when point features are edited and added from a locally shared folder, the changes fail to synchronize and update for other users accessing the project. This results in inconsistencies where the points fail to display accurately on the map.
The feature being edited is located within a OneDrive folder, which may experience occasional desynchronization. Esri only supports certain types of cloud storage and OneDrive is excluded. Thus, when a OneDrive folder connection is added to ArcGIS Pro using unconventional methods, such as creating a shortcut using the 'mkdir' command in Microsoft Command Prompt or by dragging and dropping the folder into ArcGIS Pro, the folder is not properly connected to ArcGIS Pro, which may cause desynchronization.
In this workaround, the XY point layer from its current location is exported to another folder within OneDrive. This ensures that the data is accessible and properly referenced within the ArcGIS Pro project.
In this workaround, edits made to the XY point data within ArcGIS Pro are completed and the updated feature layer is shared as a shapefile via OneDrive outside of the editing session.
Article ID: 000032056
Get help from ArcGIS experts
Start chatting now
