PROBLEM
Unable to display Snowflake geography data type in ArcGIS Data Pipelines
First Published: February 3, 2026
Last Published: March 6, 2026
In ArcGIS Data Pipelines, adding Snowflake geography data type as input to the 'Create geometry' tool displays only the basemap with no data in the map preview.
Basemap of the Snowflake geography data type displays no data
Cause
Using an incorrect geometry format in the tool's parameter prevents the data from being displayed. In this example, the WKT or WKB format is selected instead of GeoJSON.
WKT and WKB define only the geometry format and do not include coordinate semantics, so their interpretation depends on the reference system. Whereas GeoJSON defines both the format and coordinates explicitly in WGS 84. When WKT or WKB is selected, the tool does not interpret the coordinates correctly.
Solution or Workaround
Change the geometry format to GeoJSON
ArcGIS Data Pipelines consumes credits when the compute resource is active. Refer to ArcGIS Data Pipelines: Credit consumption for more information.
  1. Log in to ArcGIS Online with an organizational account.
  2. Click Content > My content and select the data pipeline. In this example, it is SNOWFLAKE_DATA PIPELINE.
    the data pipeline created on Content tab
  3. On the Overview tab, click Open in Data Pipelines.
    Click Open in Data Pipelines
  4. In Data Pipelines, ensure the pipeline connection status isĀ Connected, indicated by a blue check mark.
    Connected status with blue check mark.
  5. On the canvas, click the Create geometry tool.
    Create geometry tool in the Data Pipelines canvas.
  6. In the Create geometry pane, for the Geometry format parameter, select GeoJSON.
    Select GeoJSON from the Geometry format parameter drop-down menu of the Create geometry tool.
  7. In the Create geometry pane, click Preview to inspect the results.
    Preview button in the Create geometry pane.
  8. In the preview pane, click Map preview to view the data on the map.
  9. In the Map preview option, click the Expand Expand icon in the Map preview option. icon and select a world basemap. In this example, the Topographic basemap is selected.
    Topographic map is selected as the world basemap.
  1. Click the Collapse Collapse icon in the Map preview option. icon to view the full topographic map.
The topographic map below displays the Snowflake geography point data.
Topography map of Snowflake's geography data displays data points in the Map preview
Article ID: 000040157
Software:
  • ArcGIS Online
  • Third Party Product
  • ArcGIS Data Pipelines
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
