PROBLEM
Unable to deploy the Coronavirus Response solution in ArcGIS Pro
When deploying an ArcGIS Solution in ArcGIS Pro, the Coronavirus Response solution is not available.
Screenshot of ArcGIS Pro with the Coronavirus Response solution greyed out in the Deploy an ArcGIS Solution pane
Cause
The Coronavirus Response solution cannot be deployed to ArcGIS Enterprise. The solution is not available if the current active portal of ArcGIS Pro is set to ArcGIS Enterprise.
Solution or Workaround
Change the active portal of ArcGIS Pro to an ArcGIS Online organization and deploy the Coronavirus Response solution. Refer to ArcGIS Pro: Manage portal connections from ArcGIS Pro for more information.
Article ID: 000023139
Software:
  • ArcGIS Solutions
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
