PROBLEM
Attempts to delete a required field using the Delete Field tool fail and return the following error message in the Drop Field section:
Error: ERROR 001334 Cannot delete required field <value>
This is by design. Required fields are permanent and cannot be deleted. Refer to ArcGIS Pro: 001334: Cannot delete required field <value>. for more information.
As a workaround, export the attribute table using the Feature Class To Feature Class tool, and remove the desired field.
Article ID: 000026654
Get help from ArcGIS experts
Download the Esri Support App
