PROBLEM
Unable to create or edit features using the Edit widget in ArcGIS Web AppBuilder
First Published: February 24, 2021
Last Published: February 24, 2021
In some cases, attempting to create or edit features in ArcGIS Web AppBuilder using the Edit widget fails, and returns the message, 'Your account does not have permission to create or modify data. Or this web map does not contain any editable layers.'
The message displayed in the Edit widget
Cause
The known causes of the issue include:
  • Editing is disabled for the hosted feature layer.
  • Editing is disabled in the Edit widget custom settings.
Solution or Workaround
Depending on the cause, use either one of the options below to resolve the issue.
Enable editing for the hosted feature layer
  1. In ArcGIS Online, navigate to Content > My Content, and click the hosted feature layer to open its item details page.
  2. On the item details page, click Settings.
  3. Scroll down to the Feature Layer (hosted) section, under Editing, check the Enable editing check box.
  4. Click Save.
The Feature Layer (Hosted) section in Settings with the Enabled editing checked
  1. Relaunch the web app. The template options to create features are displayed in the Edit widget.
The Edit widget with the template options displayed
Configure the Edit widget custom settings to enable layer editing
Follow this workflow if Custom settings is selected instead of Honor settings in the web map in the Editable layers settings section of the Edit widget.
  1. In ArcGIS Online, navigate to Content > My Content, and click the web app to open its item details page.
  2. Click Edit Application.
The sidebar in the item details page with the Edit Application button
  1. Click the Widget tab.
  2. In the Widget pane, navigate to the Edit widget, and click Configure this widget icon.
Clicking the Configure this widget of the Edit tab in the Widget pane
  1. In the Configure Edit window, in the Editable layers settings section, under Custom settings, check the check box for the feature layer under the Editable column.
  2. Click OK.
The Editable layer settings in the Configure Edit window to check the Editable column of the feature layer
  1. At the bottom of the Widget pane, click Save.
The Save icon at the bottom of the Widget pane
Article ID: 000025006
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
