PROBLEM
When attempting to create a feature in ArcGIS Online Map Viewer using a form, the operation cannot be completed and the following warning message is displayed in the Editor pane:
Warning: Features cannot be created. There is an issue with the form.
As a result, new features cannot be added through the form, resulting in incomplete data and preventing data updates.
The field used in the form is removed from the feature layer, causing the form to retain the outdated field configuration and not reflect the updated schema.
Remove the deleted field from the form in ArcGIS Online
The warning message is no longer displayed, and features can be created in Map Viewer as shown below.
Article ID: 000043362
Get help from ArcGIS experts
Start chatting now
