PROBLEM
Unable to create an ArcGIS Server connection from ArcMap
Last Published: July 17, 2020
When creating a connection from ArcMap to ArcGIS Server, the connection fails and returns various errors, but not limited to:
Error:
Access to this resource is forbidden, regardless of authorization. (status code 403).
Access to this resource is forbidden, regardless of authorization error
Error:
No resource could be found at that address. (status code 404).
No resource could be found at that address error
Error:
Proxy server got bad address from remote server (verify the server is running). (status code 504).
Proxy server got bad address from remote server error
Error:
Username and password are required.
Username and password are required error
Cause
The following are possible causes:
  • An incorrect port is used.
  • Incorrect credentials are used.
  • A firewall is preventing the connection.
Solution or Workaround
Follow one of the options below depending on the cause to resolve the issue.
Use the correct port
To create an ArcGIS Server connection in ArcMap, use HTTPS port 6443 instead of HTTP port 6080 for Server URL. For example, https://gisserver.domain.com:6443/arcgis. Refer to ArcGIS Server: Components of ArcGIS URLs for more information.
To enable the use of HTTP port 6080, administrators can change the setting in ArcGIS Server Administrator Directory to allow HTTP plaintext communication through the port, however it is a less secure option. Refer to ArcGIS Server: Secure ArcGIS Server communication for more information.
Use the correct credentials
Check if the ArcGIS Server site is federated with a portal. If it is federated with a portal, use the Portal credentials. Refer to ArcGIS Server: Federate an ArcGIS Server site with your portal for more information.
The following image displays a successful ArcGIS Server connection in ArcMap.
A successful ArcGIS Server connection in ArcMap
Configure the firewall settings
To allow a connection to ArcGIS Server, remove the firewall rule on the machine blocking the connection. Refer to How To: Configure ArcGIS Server for firewalls and NAT devices for more information.
Article ID: 000023366
Software:
  • ArcMap
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
