PROBLEM
Relationship classes can be created in ArcGIS Pro to identify the correlation between features or fields in the origin table and the destination table using the Create Relationship Class tool. In some instances, a relationship class cannot be created via the Catalog pane in ArcGIS Pro, as shown in the image below.
Ensure there are no edits performed on the geodatabase folder anywhere else except within ArcGIS applications. Esri recommends making backup copies of the geodatabase to counter file corruption.
If the geodatabase contains a wrong extension, for example, .GDB instead of .gdb, rename the file geodatabase folder extension with the steps provided below.
Note: Ensure the geodatabase folder data is not accessed by any other client, simultaneously, during this operation.
C:\Users\<username>\Documents\ArcGIS\Projects
The image below displays the create Relationship Class via the Catalog pane in ArcGIS Pro.
Article ID: 000025572
Get help from ArcGIS experts
Start chatting now
