PROBLEM
Unable to create a GRID format raster in a location with a space in the path name
First Published: August 7, 2020
Last Published: August 4, 2025
On a shared network drive, trying to create an ArcInfo Workstation GRID format raster returns the following error codes:
Error 010429: Error in Grid IO: GetOpenTileChannel: Could not create tile. name: h:\gisuser\gis practice\demtest1, adepth: 32, type: 2, iomode: 1, version: 3, compression:1...
Error 010296: Error in writing raster h:\gisuser\gis practice\demtest1
Error 010067: Error in executing grid expression.
Failed to execute (Fill).
Cause
The GRID format is the raster format devised for use in ArcInfo Worktstation.  Since ArcInfo Workstations was originally written for Unix operating systems, and Unix does not allow spaces anywhere in file names or paths, data formats for ArcInfo Workstation are bound by the same constraint.  This "no spaces" mandate is still in place for data in the GRID format, even though the files are being created on a Windows operating system.
Other raster formats, TIFF, JPG, BMP, and so forth, can be created at locations with spaces in path names, but the same analysis options may not be available.
Solution or Workaround
Write the GRID to a location where there are no spaces in the path.
Article ID: 000023763
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
