PROBLEM
Unable to copy and paste images from layouts of a project to other projects in ArcGIS Pro
First Published: November 11, 2022
Last Published: April 14, 2023
In ArcGIS Pro, when copying and pasting images from layouts of a project to other layouts of other projects, the images are not visible, although the paths are retained in the Element pane as shown below.
The copied image is not visible in the layout but the path is retained in the Element pane.
Cause
  • This is due to BUG-000153448 in ArcGIS Pro 3.0.
  • The ArcGIS Pro installation is not completed.
  • The ArcGIS Pro projects are corrupted.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Locate the pasted image manually
  1. In ArcGIS Pro 3.0, select the pasted image in the layout.
The pasted image being selected in the new layout of a new project.
  1. In the Element pane, click Options and expand Picture.
  2. Click the Browse The Browse icon. icon and browse to the location of the image. Click the image.
The Browse icon being selected to browse the image.
  1. Click OK.
Restart ArcGIS Pro
Close the current session of ArcGIS Pro, and restart the local machine.
Repair ArcGIS Pro
  1. On the local machine, type control panel in the search box on the taskbar. Select Control Panel.
  2. Click Programs > Programs and Features.
  3. Right-click ArcGIS Pro and select Repair. Select Change if Repair is not available.
The Repair option being selected to repair ArcGIS Pro.
Use ArcGIS Pro 2.9 or earlier
Warning:
The instructions below include making changes to essential parts of the operating system. Esri recommends performing a backup of the operating system and files, including the registry, before proceeding.
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
Alternatively, downgrade ArcGIS Pro to version 2.9 or earlier if necessary. Perform a clean uninstall by referring to Esri Australia Technical Blog: Performing a clean uninstall of ArcGIS Pro . After performing a clean uninstall, download and install ArcGIS Pro 2.9 or earlier.
The image below shows the copied image is pasted into the layout.
The image of the copied image being pasted into the layout.
Article ID: 000028769
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
