PROBLEM
Unable to connect to basic functionality in Portal for ArcGIS
Deploying a base deployment and other ArcGIS Enterprise add-ons may result in issues with basic functionality, including (but not limited to):
  • Connecting to a portal via a web adaptor in ArcGIS Pro.
  • Unable to bring services into ArcGIS Pro.
  • Unable to configure Geo Enrichment Services.
  • Fonts and/or icons do not load within Portal for ArcGIS.
Using Fiddler to debug the web application returns the following error message:
Error:
HTTP Error 404.7 - Not Found. The request filtering module is configured to deny the file extension.
File extension filter settings are found within Internet Information Services (IIS) Manager.
Cause
Portal for ArcGIS and its underlying processes use many custom file extensions. Access to these file extensions is limited when the 'Allow unlisted file name extensions', 'Allow unlisted verbs', and 'Allow high-bit characters' options are disabled in the Request Filtering section of IIS Manager. Group policy dictates the enabled/disabled settings in IIS Manager, and they may be disabled for security purposes.
Solution or Workaround
Follow the steps below to resolve the issue:
  1. Launch IIS Manager.
  2. Select the active web server.
  3. Select Request Filtering in the IIS sub-section.
Image of the Request Filtering selection in IIS Manager
  1. Click Edit Feature Settings... to open the Edit Request Filtering Settings dialog box. Check the Allow unlisted file name extensions, Allow unlisted verbs, and Allow high-bit characters check boxes.
Image of the Edit Feature Settings selection in IIS Manager
Image of the Allow Unlisted checkboxes in the Edit Request Filtering Settings dialog box
Article ID: 000021912
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
