PROBLEM
Unable to configure the editing option when publishing a web map in ArcGIS Pro
First Published: June 2, 2022
Last Published: June 2, 2022
In ArcGIS Pro, the editing option to configure the web feature layer's operation is unavailable when publishing a web map to ArcGIS Online, rendering the web map to be non-editable in the web apps.
The image below shows the editing option is not available in the Share As Web Map pane.
The image displays the editing option is not available in the Share As Web Map pane in ArcGIS Pro.
Cause
The ‘Copy all data: Exploratory’ option under Select a Configuration is selected by default when publishing a web map to ArcGIS Online.
The image of the ‘Copy all data: Exploratory’ option is selected by default when publishing a web map.
Solution or Workaround
Use one of the methods below to resolve the issue.
Select the Copy all data: Editable option
In ArcGIS Pro, select the Copy all data: Editable option under Select a Configuration in the Share As Web Map pane, before publishing a web map to ArcGIS Online.
The Copy all data: Editable option is selected in the Share As Web Map pane.
Delete temporary files or clear the cache in ArcGIS Pro
Delete temporary files or clear the cache in ArcGIS Pro. Refer to ArcGIS Pro: How caching works for more information.
The image below shows the editing option is now available in the Share As Web Map pane.
The editing option is available in the Share As Web Map pane.
Article ID: 000027770
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
