PROBLEM
Unable to configure story maps shared with a group in ArcGIS Online
First Published: December 9, 2020
Last Published: July 22, 2026
In ArcGIS Online, group members are unable to configure story maps shared with the group despite having the permission to contribute to the group.
Cause
  • The group members do not have administrative privileges to access the configuration settings of the story maps.
  • The story maps are not shared with a shared update group.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
Only administrators can perform the following workflows.
Change the member’s default role to an administrative role
Change the member’s role to a default Administrator role to enable access to the configuration settings of the shared story maps. Refer to ArcGIS Online: Change member roles for steps to do so.
Update the member’s custom role to enable administrative privileges
Update the member’s custom role to enable the Update option in the Administrative privileges settings. Refer to ArcGIS Online: Configure member roles for more information.
Image showing the Create role window with the Update option toggled on
Share the story maps with a shared update group
Create a shared update group to allow members to update shared items in the group, and share the story maps with the group.
  1. Create a shared update group. Refer to ArcGIS Online: Create a group for steps to do so. For What items in the group can its members update?, ensure All items (group membership is limited to the organization) is selected.
Image showing the All items setting selected
  1. Share the story map with the newly created shared update group. Refer to ArcGIS Online: Share items with a group for more information.
Article ID: 000024599
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
