PROBLEM
Unable to configure layer actions in ArcGIS Dashboards
First Published: November 18, 2021
Last Published: November 18, 2021
When attempting to configure layer actions (flash, filter, and pan) for a map element in ArcGIS Dashboards, the message ‘No layers found for actions’ is returned, as displayed in the image below.
A message is returned on the Map page when attempting to add layer actions in the Map element.
In a situation where layer actions are configured in the map element, clicking certain map features using the selection tool causes the tool to load indefinitely.
The selection tool loads indefinitely when selecting certain features on the map.
Cause
The web map in the dashboard contains map image layers. A dashboard’s web map can contain map image layers, but it is a known limitation that layer actions are not supported for map image layers.
Solution or Workaround
Instead of using map image layers, publish the data as feature services to configure layer actions for the elements in ArcGIS Dashboards. For steps, refer to ArcGIS Server: Feature service publishing options or ArcGIS Online: Publish hosted feature layers.
Article ID: 000026818
Software:
  • Portal for ArcGIS
  • ArcGIS Dashboards
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
