PROBLEM
Unable to collect data in ArcGIS Field Maps
First Published: May 6, 2021
Last Published: July 29, 2025
Attempts to collect data in the ArcGIS Field Maps app fail, and return the following message, "The form contains unsupported data."
The form contains unsupported data error when collecting data in ArcGIS Field Maps.
Cause
  • There are special system fields added to the form that are not supported.
  • There are corrupted layers.
Solution or Workaround
Depending on the cause, choose one of the workarounds below to resolve the issue:
  • Update the ArcGIS Field Maps app to the latest version.
To check the version of the ArcGIS Field Maps app, open the app and navigate to Profile > About Field Maps. The App Version and Build number are displayed on the About Field Maps page.
  • Remove the corrupted layers and replace them with new layers.
Article ID: 000025521
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
