PROBLEM
Unable to change ownership of items to another member in ArcGIS Online
First Published: July 15, 2024
Last Published: July 15, 2024
When attempting to change ownership of an item to another member in ArcGIS Online, the check box next to the member's name is unavailable.
The image of the check boxes being missing next to the name of the members in ArcGIS Online.
Cause
The user does not have administrative privileges to transfer ownership of items in ArcGIS Online.
Solution or Workaround
To resolve the issue, use one of the following workflows.
Contact the organization's administrator
Contact the organization's administrator to transfer the ownership content to another member.
Assign a custom role to the user
Only an organization's default administrator or a member with administrative privileges can perform the following workflow.
Create a custom role with administrative privileges to transfer item ownership. Refer to ArcGIS Online: Administrative privileges for more information.
  1. Create a custom role with the capability to transfer item ownership. Refer to ArcGIS Online: Configure member roles for instructions.
  2. Assign the custom role to the user. Refer to ArcGIS Online: Change member roles for further instructions.
Article ID: 000032759
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
