PROBLEM
Unable to calculate statistics or build pyramids on an SDE raster stored in a SQL Server 2005 database.
Calculating statistics or building pyramids on an SDE raster dataset stored in a SQL Server 2005 database results in a failure of the geoprocessing tool or a crash of the ArcGIS application. If the process was initiated in the SDE command line, the process does not complete.
Cause
This behavior occurs when SQL Server 2005 does not have Service Pack 2 installed, which is a requirement for SDE at 9.3 (see the System Requirements page). To determine what build of SQL Server is currently installed, review the corresponding Microsoft article in the Related Information section below.
Solution or Workaround
Install Service Pack 2 for SQL Server 2005. The download link from Microsoft's Web site is available in the Related Information section below.
    Article ID:000010325
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
