PROBLEM
Unable to authorize ArcGIS Server 11.x using the Software Authorization wizard
First Published: July 18, 2023
Last Published: June 12, 2026
In an ArcGIS Enterprise deployment, attempts to authorize ArcGIS Server 11.x on a machine using the Software Authorization wizard fail and return the following error:
Error:
Failed to create the base deployment because ArcGIS Server does not have a valid license. Please authorize using the Software Authorization for ArcGIS Server wizard.
Cause
  • The authorization file used is intended for earlier versions of ArcGIS Server.
  • The authorization file used is corrupted.
Solution or Workaround
Create a new authorization file from My Esri and reauthorize ArcGIS Server on the machine using the Software Authorization wizard.
Article ID: 000030733
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
