PROBLEM
The upper() function cannot be applied to convert the input text to uppercase in an ArcGIS Survey123 Connect XLSForm, resulting in inconsistent data formatting that affects data analysis and reporting.
Although the UPPER function is supported in Microsoft Excel, it is not included among the standard XLSForm functions supported by ArcGIS Survey123 Connect. As a result, it cannot be applied to convert the input text to uppercase. Refer to ArcGIS Survey123: Functions for more information.
Depending on the question type used in the ArcGIS Survey123 Connect XLSForm, use one of the workarounds below to convert the input text to uppercase.
>xxxxxxxxxxx
The ‘x’ character represents the maximum number of characters permitted in the column. Specify the preferred number of the ‘x’ character. Refer to ArcGIS Survey123: Input mask for more information.
minimal (${<field_name>})
autocomplete (${<field_name>})
Note: The ‘minimal’ appearance is suitable for short choice lists, while the ‘autocomplete’ appearance narrows the available choices as input is specified. Refer to ArcGIS Survey123: Appearance for more information.
Replace <field_name> with the value in the name column. In this example, ‘food’ is specified.
The input for the question is in uppercase.
Article ID: 000043246
Get help from ArcGIS experts
Start chatting now
