PROBLEM
Unable to add point features beyond the user’s location in ArcGIS Field Maps
First Published: March 2, 2023
Last Published: March 2, 2023
Mobile workers use ArcGIS Field Maps to collect data and perform inspections on the field. In some instances, the Add Point button is disabled for an ArcGIS Enterprise feature service when the cross-hairs are moved beyond the location of the user in ArcGIS Field Maps, as depicted in the images below.
The Add Point button is available with the map crosshairs within the location of the user. The Add Point button is unavailable when the map crosshairs is beyond the location of the user.
Cause
The ‘Apply default to features with z-values’ check box is unchecked. When the feature layer is z-aware and does not have a default z-value configured, point features cannot be manually added when the map cross-hairs are moved beyond the current location as the z-value is not generated. However, the point feature can be added within the current location of the user as the GPS-derived location provides the z-value.
Solution or Workaround
Check the 'Apply default to features with z-values' check box in ArcGIS Server. Refer to ArcGIS Server: Configure default z-values for editable feature services for further instructions.
The image below shows the Add Point button enabled when the map cross-hairs are beyond the location of the user in ArcGIS Field Maps.
The Add Point button is available with the map crosshairs beyond the location of the user.
Article ID: 000029556
Software:
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
