PROBLEM
Unable to add new features to a z-enabled ArcGIS Online feature service
In ArcGIS Online and other mobile applications, new features cannot be added to an editable feature service when clicking the web map to add a feature. When a location on the map is clicked to add a new feature, the feature does not display.
Cause
The feature service is z-enabled, but does not have a default z-value established. A z-value is not interpolated automatically in ArcGIS Online web maps and applications because ArcGIS Online is designed to be two-dimensional.
If a default z-value for the feature service is not specified, the z-value for the new feature is set to NULL. This is by design. Since geometric properties of a feature cannot be NULL, no new features can be created.
Solution or Workaround
Enable and set a default z-value for the feature service. To do so, follow the instructions provided below.
  1. On the Item Details page of the feature service, select Service URL.
  2. Go to the admin REST endpoint page by adding /admin/ between /rest/ and /services/ in the service URL. For more information, refer to How to Update Your Hosted Feature Service Schemas in ArcGIS Online.
The REST admin page of the feature service
  1. Click Update Definition at the bottom of the admin page.
  2. In the Update Layer Definition box, scroll down to search for the enableZDefaults parameter, and change the value from false to true.
  3. Assign a value for the zDefault parameter (default z-value). The default value is 0.
Change the enableZDefaults parameter to true, and set the zDefault parameter to 0
  1. Scroll to the top of the Update Layer Definition box to search for the lastEditDate parameter, and replace the string of numbers that indicate the last edit date with double quotation marks, as shown below.
Replace the string of numbers for the lastEditDate parameter with double quotation marks
  1. Click the Update Layer Definition button to apply the updates.
Article ID: 000014239
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
