PROBLEM
Unable to add global IDs to a shapefile with the Add Global IDs tool
First Published: August 12, 2020
Last Published: September 1, 2020
When adding global IDs to a shapefile using the Add Global IDs tool, the geoprocessing fails with the following error:
Error:
ERROR 000540: The workspace is not supported.
Image showing the Add Global IDs geoprocessing tool fails with the error.
Cause
Shapefiles use the dBASE file format (.dbf file) to store attributes. Since dBASE files do not support the global ID field type, they cannot be added to shapefiles. Global IDs are the properties of file geodatabases, feature classes, or tables.
Solution or Workaround
Convert the shapefile to a feature class before adding global IDs by following the steps below.
  1. In ArcMap, create a file geodatabase. Refer to ArcMap: Create a file geodatabase for more information.
  2. Import the shapefile (.shp) to the newly created file geodatabase. Refer to ArcMap: Importing a feature class (single) for more information. The imported shapefile is converted to a feature class.
The feature class is added to the map automatically, and is shown under the file geodatabase in the Catalog window. If it is not, right-click the file geodatabase, and click Refresh.
  1. Use the Add Global IDs tool to add global IDs to the feature class from Step 2 in the file geodatabase. Refer to ArcMap: Add Global IDs for more information.
Article ID: 000023884
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
