PROBLEM
Unable to add Mobile Workers to a group in ArcGIS Online
Last Published: January 2, 2024
Attempts to add users with a Mobile Worker user type to a group in ArcGIS Online fail, and return the following message in a Notification pop-up window:
Image of the Notification pop-up window.
The added users do not receive the invite notification to the group.
Cause
  • The added users are external users from another organization.
  • The group setting for ‘What items in the group can its member update?’ is set to ‘All items (group membership is limited to the organization)’. This allows access and update capabilities to group members. Thus, group membership is limited to users with the privileges to create, update and delete content. However, the Mobile Worker user type is limited to only editing and viewing privileges.
The "What items in the group can its member update?" setting may not be available if the Shared Update group setting is enabled.
Solution or Workaround
Select one of the options below to resolve depending on the cause.
Only the user's organization administrators can perform this workflow.
Create a custom role for the external user, and enable the Join external groups setting in the Groups section under Role privileges in the Create role window. Refer to ArcGIS Online: Configure member roles for more information.
Image of the Join external groups setting is enabled
The group setting limits membership to users with the privileges to create, update and delete content
Create a new group and select the Only their own items option for What items in the group can its member update? Refer to ArcGIS Online: Create groups for more information.
Image of the Select Only their own items option
Article ID: 000024115
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
