PROBLEM
Unable to add data from personal geodatabases in ArcGIS Pro
First Published: June 3, 2021
Last Published: November 2, 2023
In ArcGIS Pro, personal geodatabases (.mdb) are not displayed in the Add Data window when attempting to add data to a project.
The image below shows only a file geodatabase is displayed in the Add Data window, and only feature classes or tables stored in the file geodatabase can be added.
The Add Data window.
Cause
Personal geodatabases are not supported in 64-bit ArcGIS applications such as ArcGIS Pro and it is not possible to use or edit data stored in personal geodatabases in ArcGIS Pro. Therefore, personal geodatabases are not displayed when attempting to add data to an ArcGIS Pro project.
Solution or Workaround
Although personal geodatabases are not supported in ArcGIS Pro, it is possible to connect to the personal geodatabases and view the data by creating an Object Linking and Embedding Database (OLE DB) connection. This creates read-only connections to access tabular data sources from the personal geodatabases.
  1. Open the project in ArcGIS Pro.
  2. On ribbon, click theĀ Insert tab. In the Project group, click Connections > Database > New OLE DB Connection.
The New OLE DB Connection option from the Insert tab.
  1. In the Data Link Properties dialog box, on the Provider tab, select the appropriate provider based on the Microsoft Access Database Engine driver installed and click Next.
    • Select Microsoft Office 12.0 Access Database Engine OLE DB Provider if the Microsoft Access Database Engine 2010 Redistributable driver is installed.
    • Select Microsoft Office 16.0 Access Database Engine OLE DB Provider if the Microsoft Access Database Engine 2016 Redistributable driver is installed
The 'Microsoft Office 12.0 Access Database Engine OLE DB Provider' option in the Data Link Properties window.
  1. On the Connection tab, for Data Source, specify the personal geodatabase path and click Test Connection to validate the connection information.
  2. Click OK.
The data source specified in the Data Link Properties window.
To copy the personal geodatabase path on Microsoft Windows, open the ArcGIS project folder in File Explorer. Right-click the file and select Copy as path.
The personal geodatabase file in the File Explorer window.
The read-only tabular data stored in the personal geodatabase from the OLE DB connection is added to the Catalog pane.
The tabular data from the personal geodatabase is displayed in the Catalog pane.
Article ID: 000025724
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
