PROBLEM
Unable to add an additional block between a story navigation bar and an existing block in ArcGIS StoryMaps
Last Published: February 21, 2023
In ArcGIS StoryMaps, adding a new block between the story navigation bar and an existing block is not possible, as the 'Add content block' button is not displayed when the cursor hovers over the white space.
The white space in between the story navigation bar and the existing block
Cause
This is by design. When a block is added to a story and the story navigation bar is enabled, it is not possible to add a new block between the story navigation bar and the existing block.
Solution or Workaround
To solve the issue, add a new block below the existing block and place it between the story navigation bar and the existing block.
  1. Open the story in ArcGIS StoryMaps.
  2. Click More actions > Edit story.
The Edit story option
  1. In the story builder, hover below the existing block, click the Add content block The Add content block button button, and select an option from the block palette to add a new block. In this example, the Text block is added to the story.
The Text block option from the block palette
  1. Type the desired text in the new block. Refer to ArcGIS StoryMaps: Add narrative text for more information.
  2. Hover over the new block, click and hold the Drag to reorder icon to drag and place the block between the story navigation bar and the existing block.
The Drag to reorder icon
Steps 6 and 7 only apply to a published story.
  1. In the story builder header, click Publish.
The Publish button in the story builder header
  1. On the Publish options page, click Publish to publish the changes made to the story.
The Publish button on the Publish options page
The image below shows the Text block successfully placed between the story navigation bar and the existing block.
The new block, which is placed in between the story navigation bar and the existing block
Article ID: 000029358
Software:
  • ArcGIS StoryMaps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
