PROBLEM
Unable to add a routing utility service to the Directions widget in ArcGIS Experience Builder
First Published: May 23, 2024
Last Published: June 18, 2024
When configuring the Directions widget in ArcGIS Experience builder, a routing utility service must be added to enable its functionality. The following generic error message is returned when attempting to add a routing utility service:
Error:
This utility service is not supported.
The image below shows the error message displayed when entering the service URL in the Add utility panel.
The error message returned when entering the service URL in the Utility service panel
Cause
A travel mode is not configured on the network dataset the routing utility service is sourced from. The Directions widget requires a mode of transportation to calculate the fastest route from one location to another by distance or time. This is achieved through the retrieve travel modes service, which retrieves supported travel modes configured on the network dataset when performing a network analysis.
Solution or Workaround
  1. In ArcGIS Pro, create a travel mode for the network dataset.
  2. Republish the service and add it to the ArcGIS Experience Builder web app.
Article ID: 000032722
Software:
  • ArcGIS Online
  • ArcGIS Enterprise
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
