PROBLEM
Unable to add a database connection as a data store item to Portal for ArcGIS
First Published: August 6, 2020
Last Published: September 24, 2020
Starting with Portal for ArcGIS 10.7.1, data sources can be added as a data store item to Portal for ArcGIS, allowing it to be shared with any of Portal's federated servers.
In some cases, adding a database connection as an item fails, freezing the software during the import process.
Image of the import process failing and causing the software to freeze
If Portal does not have a designated hosting server, this process fails within the Portal GUI. Opening Developer Tools in a web browser displays the following JavaScript error:
Error:
Uncaught TypeError: Cannot read property 'adminUrl' of undefined
at Object._uploadConnectionFile (content.js:3415)
at Object._processConnectionFile (content.js:3412)
Cause
Portal for ArcGIS does not have a designated hosting server.
Solution or Workaround
Designate a hosting server for Portal for ArcGIS. Refer to Specify the hosting server for steps to do this.
Alternatively, register the database connection as a data store in ArcGIS Server, and use the Federate Data Item admin API to add this data store as a data store item in Portal.
Article ID: 000023939
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
