PROBLEM
Unable to access the ArcGIS Enterprise portal configured with Integrated Windows Authentication or Single Sign-On
First Published: January 9, 2021
Last Published: March 11, 2021
In some instances, when an organizational user attempts to log in to an ArcGIS Enterprise portal site configured with either an Integrated Windows Authentication (IWA) or Single Sign-On (SSO), the login fails and the user is unable to access the portal site. The following error message is returned:
Error:
Invalid username or password.
Cause
The user's machine Internet options settings page is not set to automatic logon for User Authentication.
Solution or Workaround
The following workaround may require the assistance of a system administrator. Consult a qualified computer systems professional if necessary.
Follow the workaround to set the internet options to automatic for User Authentification.
  1. On the user's machine, navigate to Control Panel.
  2. Click Network and Internet.
  3. Click Internet Options.
  4. In the Internet Properties window, on the Security tab, click Local intranet.
  5. Click Custom level....
The Custom level setting of Local intranet in the Internet Properties set up page.
  1. Under Settings, scroll to User Authentication, select Automatic logon only in Intranet zone, and click OK.
The selection of User Authentication Logon setting of the Automatic logon only in Intranet zone selection in the Security Settings of the Local  Intranet Zone page.
  1. Restart the machine, and log in again to the ArcGIS Enterprise portal.
Article ID: 000024981
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
