PROBLEM
ArcGIS Enterprise allows the sharing of ArcGIS Server services by connecting ArcGIS Server Manager to the ArcGIS organization and referencing the service URL. In some cases, attempts to access a shared service via the service URL in ArcGIS Online Map Viewer fail, and return one of the following error messages:
Error: The layer, <LayerName>, cannot be added to the map.
Error: Unable to create map: Unable to load the base map layer
The service URL is configured using a Local Area Network IP address. This configuration only allows connections within the same on-premise network, and cannot be connected to externally.
In ArcGIS Enterprise, configure the ArcGIS Enterprise portal with ArcGIS Web Adaptor. Refer to ArcGIS Enterprise: Configure ArcGIS Web Adaptor for more information. After configuring ArcGIS Web Adaptor, access the ArcGIS Enterprise services via the newly configured Web Adaptor service URL.
Article ID: 000028648
Get help from ArcGIS experts
Start chatting now
