PROBLEM
Unable to access feature layers in ArcGIS Dashboards
Last Published: June 5, 2020
When configuring an action on an element in ArcGIS Dashboards, selecting a feature layer fails, returning the following error message:
Error:
Layer not accessible.
Image of the error message
Cause
The feature layers used to configure the action are added as feature collections in ArcGIS Online or Portal for ArcGIS.
Solution or Workaround
To resolve this issue, republish the feature layers as hosted feature layers for use in ArcGIS Dashboards. Check the Publish this file as a hosted feature layer. (Adds a hosted layer item with the same name.) check box when republishing the hosted feature layers to ArcGIS Online or Portal for ArcGIS. Refer to ArcGIS Online: Publish hosted feature layers and Portal for ArcGIS: Publish hosted feature layers for more information.
Image of the 'Publish this file as a hosted feature layer' check box.
Article ID: 000023127
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
