PROBLEM
Unable to access ArcGIS Server map services from external applications
First Published: October 21, 2025
Last Published: March 12, 2026
Certain ArcGIS Server map services cannot be loaded in a third-party application, although the same services are accessible in ArcGIS Map Viewer. When inspecting the request in the browser Developer Tools, the following Cross-Origin Resource Sharing (CORS) error is returned:
Error:
<domain> has been blocked by CORS policy: the value of the 'Access-Control-Allow-Origin' header in the response must not be the wildcard '*'.
This indicates the browser blocks the request due to CORS policy enforcement, preventing the third-party application from accessing the ArcGIS Server REST service.
Cause
ArcGIS Server uses the allowedOrigins parameter to determine which domains are permitted to make cross-origin requests to REST services. In this case, the parameter is configured with an unsupported value (*survey123). Only fully qualified domain names or the wildcard * are supported. Because the configured value does not match the requesting domain, ArcGIS Server does not return a corresponding Access-Control-Allow-Origin header. As a result, the browser blocks the request due to CORS policy enforcement. The services remain accessible in ArcGIS Map Viewer because the application accesses the service from an allowed origin or through a proxy.
Solution or Workaround
  1. Log in to the ArcGIS Server Administrator Directory as an administrator.
  2. Navigate to system > handlers > rest > servicesdirectory.
  3. On the Services Directory page, for Supported Operations, click edit.
  4. Locate the AllowedOrigins parameter.
  5. Remove *survey123 and update the value to *.
  6. Click Save.
Article ID: 000038664
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
