PROBLEM
In ArcGIS Online and the ArcGIS Enterprise portal, long attribute values are not wrapped, causing important information to be truncated, and short values leave excessive spaces in the attribute table.
The attribute table is designed to maintain a compact table view in ArcGIS Online and the ArcGIS Enterprise portal. Text wrapping is not available by default, and column widths are automatically set.
Note: This workflow applies to both truncated values and excessive spaces in the attribute table. It provides a temporary view of the attribute values, but the adjusted column widths are not preserved when the web map is refreshed.
Note: This workflow is effective for truncated values and is recommended when only a few truncated values are present in the attribute table.
The image below displays the full attribute value in Map Viewer.
Article ID: 000034967
Get help from ArcGIS experts
Start chatting now
