PROBLEM
There are a number of common issues when setting up a Portal for ArcGIS to ArcGIS Online distributed collaboration. One issue is the 'Not Yet Joined' status display in the ArcGIS Online workstation. The status in ArcGIS Online indicates Portal for ArcGIS has not joined the collaboration. It is not possible to sync content until both Portal for ArcGIS and ArcGIS Online indicate the 'Joined' collaboration status. Review the Portal for ArcGIS log records for events or errors associated with the events to gain clarification on the issue.
Below is an example of a message displayed in Portal's logs.
Collaboration invitation validation failed for Collaboration invitation validation completed. Existing collaboration with id 'xxxxxxxxxxxxxxxxxxxxxx' found. Invitation for this collaboration was already previously accepted. The certificate authority that issued the SSL certificate needs to be trusted by Portal before the invitation can be accepted.
To determine if Portal for ArcGIS can communicate with ArcGIS Online, use the checkUrl.jsp page. Navigate to the following URL on a web browser:
https://portal.domain.com/portal/sharing/checkUrl.jsp?url=https://www.arcgis.com
If the message described below is returned, a troubleshoot of Portal's internet connection settings is required.
"success": false,
"error": {"message": "Unknown Exception"}
Note: The following workarounds must be performed by the organization's IT personnel.
Ensure the certificate configured with Portal for ArcGIS matches the Portal URL used to create the collaboration.
For a collaboration to succeed, Portal for ArcGIS needs outbound access to ArcGIS Online. Determine if a connection is established between Portal and ArcGIS Online.
Article ID: 000020005
Get help from ArcGIS experts
Start chatting now
