PROBLEM
Triangles are drawn at the corner of a dashed line that is offset
For all types of dashed lines that have an offset value, a triangle may be noticeable for 'V' shaped segments. The higher the offset value the more noticeable this effect will be. For most small-scale maps this should not be a problem. However, zooming into one of these areas, or printing at a larger scale may make this more evident.
Cause
This is a known issue in the drawing algorithm used for offset lines. It is only a display issue and does not reflect the actually geometry of the feature.
Solution or Workaround
  • Reducing the amount of offset can minimize or eliminate the effect.
  • The error will be less evident as you zoom out of the area in question.
Article ID: 000002816
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
