PROBLEM
Under some circumstances, geoprocessing tools and toolbars open with blank dialog windows. The buttons (OK, Cancel, Environments, etc.) still function properly. There may also be a working scroll bar in the portion of the dialog where input and output parameters are entered, but fields or settings are not visible.
The registry key that references the vbscript.dll and other .dlls necessary for tool function are overwritten by McAfee antivirus software. When McAfee antivirus software is uninstalled, the registry keys are not restored to the native format. This issue may also appear with Avast antivirus software. To confirm this is the cause, follow these steps:
HKEY_CLASSES_ROOT\CLSID\{B54F3741-5B07-11cf-A4B0-00AA004A55E8}
HKEY_CLASSES_ROOT\CLSID\{B54F3741-5B07-11cf-A4B0-00AA004A55E8}\InprocServer32
HKEY_CLASSES_ROOT\CLSID\{EE09B103-97E0-11CF-978F-00A02463E06F}\InprocServer32
If McAfee is currently installed and must remain in use, contact McAfee for assistance. If McAfee is installed but not required on the computer, then uninstall it before proceeding with the solution below. After McAfee antivirus software is uninstalled, follow the steps below to resolve the issue.
Article ID:000011764
Get help from ArcGIS experts
Download the Esri Support App
