PROBLEM
TIN Builder dialog assigns tag values even though they aren't requested
This problem is addressed in ArcGIS 8.1 Service Pack 1. See the Related Information section to download this pack.
If the TIN Builder dialog is used to create a TIN, it may add tag values even though they weren't requested.
If points were input to the output TIN, it will have node tag values set to the point OIDs. If polygons were used the TIN will have triangle tag values set to the polygon OIDs.
Cause
This is a known issue.
Solution or Workaround
If the tag values are posing a problem:
- for nodes delete tnval.adf and tndsc.adf files under the TIN folder.
- for triangles delete ttdsc.adf and ttval.adf files under the TIN folder.
    Article ID:000003752
    Software:
    • ArcMap 8 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
