PROBLEM
When attempting to configure the tiling option while printing a map series layout, the tiling option is disabled. The tiling option previews the printed layout and determines the scale of the layout on the printed paper. The image below shows the Tiling option disabled in the Print Layout pane.
This is expected behavior because tiling options are not supported when printing layouts with any map series set as their map frames.
The following is the workflow on how to enable the tiling option before printing the layout.
.Note: To disable map series for all layouts, click the Insert tab on the ribbon. In the Map Frames group, click the Map Frame drop-down arrow and select <None>.
The image below shows the Tiling option available in the Print Layout pane.
Article ID: 000032826
Get help from ArcGIS experts
Start chatting now
