PROBLEM
Tile layer not visible in ArcGIS Online
Last Published: March 31, 2026
When opening a tile layer in ArcGIS Online Map Viewer, the tile layer is not visible on the map.
The map view in ArcGIS Online Map Viewer.
Cause
The level of detail (LOD) of the tile configuration is too low for the tile layer to be visible. The LOD represents the zoom level for a map view or scene view and displays various levels of details based on the configured LOD, where lower levels are furthest from the earth with smaller scales, while higher levels are closer to the earth with larger scales, and can zoom in to the extent of streets, buildings, and houses.
Solution or Workaround
  1. Start ArcGIS Pro.
  2. In the Contents pane, right-click the layer and click Sharing > Share As Web Layer.
  3. In the Share As Web Layer pane, click the General tab.
  4. For Layer Type, select Tile.
  5. Click the Configuration tab.
  6. For Levels of Detail, use the sliders to set the appropriate map scales for which tiles are generated. In this example, Level 11 (Metropolitan Area) and Level 18 (Buildings) are set.
The Share As Web Layer pane in ArcGIS Pro.
  1. Share the web layer. Refer to ArcGIS Pro: Share a web tile layer using the default configuration for further instructions.
The tile layer is now visible in ArcGIS Online Map Viewer, as shown below.
the map view in ArcGIS Online Map Viewer.
Article ID: 000031377
Software:
  • ArcGIS Pro
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
