PROBLEM
'This widget does not support style settings' message displayed when configuring a widget in ArcGIS Experience Builder
First Published: September 9, 2026
Last Published: September 9, 2026
In ArcGIS Experience Builder, the 'This widget does not support style settings' message is displayed when configuring a widget within the Widget Controller widget. As a result, the widget’s dimensions cannot be set to specific values from the Style tab.
The This widget does not support style settings message
Cause
This is expected behavior, as the size and layout of the widget panel are configured in the Widget Controller's settings. The widget’s dimensions cannot be configured independently using the Style tab.
Solution or Workaround
Resize the widget panel with one of the options provided.
  • In the Widget Controller panel, on the Content tab, if Floating is selected under Widget panel arrangement, click and drag the four corners of the widget panel to set the preferred dimensions. These dimensions apply to the individual widget and must be set separately for each widget.
  • In the Widget Controller panel, on the Content tab, if Fixed is selected under Widget panel arrangement, set the preferred dimensions under Position & size. These dimensions apply to all widgets within the Widget Controller.
Widget panel arrangement for Fixed selection
Some widgets have limited control over dimensions when positioned inside the Widget Controller widget. Refer to FAQ: Can widgets in the Widget Controller widget be repositioned in ArcGIS Experience Builder? for more information.
Article ID: 000043151
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
